Is there a way to schedule the issuing of tasks?
Abdallah AlSurakji June 13, 2022
Hyello,
I'm wondering if there is a way to schedule when a task could be assigned to a user? The idea is to assign the task to a user at a certain date to not clutter their view. For example, it could be unassigned, an on the selected date, assignee will change.
David Freitez
June 13, 2022
Hi @Abdallah AlSurakji
It is feasible using Automation, you can use:
  • The Scheduled Trigger
  • The Create Issue Action
Hopefully this answers your question.
David
ServiceRocket
Abdallah AlSurakji June 14, 2022
Thanks for taking the time to answer David,
So as I suspected, the only way around this issue is with the Automation plugin then.
 All the best :)
Register now
