When I create an issue, this issue have a different workflow diagram according to a field value, I just want to know if I can use a script (python or JS) to do it.
I think not, I should create 2 differents issues but I just ask it.
Thanks you.
I think you're talking about changing the workflow depending on the value of a custom field? (And not diagrams per se.)
You can switch the issue type in a post-function depending on the value of the CF, and this other issue type could have a different WF. But, the code to do an issue move is bit difficult...
Register now
