They appear to the left of the Epic column if you have them enabled (i.e. at least one issue has a version set)
Thanks Nic, but I mean on the Active sprint board with the columns or swim lanes. So on each issue I'd like to see the version and not the Epic which appears to be the default.
Ok, have you tried adding the versions to the card layouts?
