Is there a way to un-watch multiple issues ?
Vishnukumar Vasudevan
Guys,
Any work around to un-watch or watch multiple issues ?
We can't edit watchers list via bulk edit.
Fyi, I use jira 4.4.1 and 4.4.5.
Thanks, Vishnu.
7 votes
Michael Villis January 27, 2015
This feature has now been added to the Bulk Issue capability in JIRA (>= 6.0).
See the Watch / Stop Watching section of this article: https://confluence.atlassian.com/display/JIRA/Modifying+Multiple+(Bulk)+Issues
Vladimir Alexiev
You can use the Jira CLI.
The latest free version 2.6.0:
https://bobswift.atlassian.net/wiki/download/attachments/16285777/jira-cli-2.6.0-distribution.zip?api=v2
Use these actions:
Say <my-user> wants to unwatch all except project <interesting>. Adjust the "jira" batch file, then run this:
jira --action runFromIssueList --search "key in watchedIssues() and project!=&lt;interesting&gt;"
  --common "--action removeWatchers --issue @issue@ --userId &lt;my-user&gt;"
Rick Pearson April 1, 2013
Thanks! That CLI works great. Just as advertised!
Mike Diehn May 22, 2014
And it *still* works well! :-) I've got 4058 issues in my watchedIssues() list, though, so I need the --limit option as well. Here's an example for people as unfamiliar with the CLI tools as I was a few weeks ago:
./atlassian-cli-3.8.0/atlassian.sh jira --action runFromIssueList --search 'key in watchedIssues() and category not in ("DevOps Projects", "IT Projects")' --limit 1000 --common "--action removeWatchers --issue @issue@ --userId mdiehn"
Jonny Carter June 23, 2015
This is enabled in JIRA 6.0 and later. See Michael Villis's answer, below.
Vadim Efimov February 25, 2015
Here's a quick JavaScript for bulk stop watch (will not require any tools other then your browser):
https://gist.github.com/qvaqvaboo/1abbec8054b26dbdd4ae
Reyhan Sadaka May 28, 2013
Here's a quick Python script that will work as long as you have add/remove watcher rights on the project(s) you are trying to affect (or are just working on yourself).
It requires the Requests library (http://docs.python-requests.org/en/latest/) but since it runs through the REST API requires much lower access than CLI.
import json
import requests
WebSession = requests.Session()
WebSession.auth = ('username','password') #JIRA Credentials go here, Optionally use Base64 Encode/Decode
WebParams = {'jql':'watcher = currentUser()', 'fields':'key', 'maxResults':'9999'} #You can use basically any JIRA search query here in the JQL parameter
WatchList = WebSession.get('https://JIRA Root URL Here/rest/api/latest/search', params=WebParams) #Fill in your JIRA Root
WebParams = {'username': 'User'} #Insert User Name of watcher to delete here, probably yours
for k in WatchList.json()['issues']:
   print 'Removing Watcher ' + WebParams['username'] + ' from issue ' + k['key']
   WebSession.delete('https://JIRA Root URL Here/rest/api/latest/issue/'+k['key']+'/watchers', params=WebParams) #Fill in your JIRA Root
Renjith Pillai
February 17, 2013
umutkirgoz February 12, 2013
Vladimir Alexiev
There are two userscripts that are supposed to do this:
JIRA Watch All Issues User Script for Greasemonkey
JIRA 5 Watch All Issues User Script for Greasemonkey
(Greasemonkey is a FF extension; Chrome runs user scripts natively).
Unfortunately none of them works for me (see Reviews tab there). Please try them and write if they work for you
RambanamP
June 14, 2012
Through gadget we can add or remove watchers,
just you need to develop gadget to add or remove watchers to filter.
Thomas Heidenreich
June 13, 2012
No, but there is an issue for you to vote on: https://jira.atlassian.com/browse/JRA-2429
Thanks guys. I added my vote. But it's ideal for last 9 years :(
Jobin Kuruvilla [Adaptavist]
June 13, 2012
Nope that is not possible at the moment. I have done this via database in the past!
