Is there any option to have a custom field value as a issue filter result
S
April 3, 2012
Hi All,
Please suggest me, is there any option to have a custom field value should be matching as result of a issue filter. Also name the plugin if they will have this functionality.
Many Thanks,
Sanu P Soman
Nic Brough -Adaptavist-
April 3, 2012
Er, that doesn't make a lot of sense, sorry. It sounds like you want to define a field which will have a load of issues in it, which will dynamically change as the data it's filter is based on changes naturally.
That would be an absolute nightmare to write because you'd have to be constantly updating the index to make the content match the results of your filter and that's just an insane load.
I could be completely misunderstanding the question (happens a lot in my life), so may I ask you to explain the actual goal, instead of what you think might be a solution? I.e. what is the problem you are trying to solve?
