Is there any possible way to restrict the subtask status change until parent task status change??
sudhakar reddy May 17, 2016
please help
Ligia Merciu
Hi Sudhakar,
You could also add a SIL scipted condition, using JJUPIN.
Arun_Thundyill_Saseendran
May 17, 2016
Hi Sudhakar
The inverse is easily possible using the "Sub Task Blocking" condition in the workflow transition.
The one you are asking is also possible if you add a scripted condition using the ScriptRunner plugin in the workflow transition condition in your sub-task transition to the state you want. All you have to do is to check the status of the parent issue and if it is in the desired state, pass a true else false.
@Arun Thundyill Saseendran
Let's build A Rovo Agent 🤖
Save your spot
