×Hi ,
Is there any way to add a fix version from another project to a issue?
For example, I have a task in Project-A and i wanna to add it to a fixVersion which was created in Project-B.
Olive
What @Alexey Matveev suggest may not be good for you as it's only for old Jira versions (5.0-5.0.7) and it cost money.
Better option will be:
https://marketplace.atlassian.com/apps/823187/releasedog?hosting=server&tab=overview
which is for newer versions (7.00-7.11.2) and it's free.
You can not do it out of the box. But you could use a pluign like this:
