Is there any way to have context sensitive Service Desk fields? Showing fields based on others?
Daniel Pasacrita August 18, 2017
So that title is a little confusing, but what I want to do for our service desk is make it so that you can select a radial button option, and based on that selection one of two different fields can appear.
Customer selects "YES" -> Field 1 appears
Customer selects "NO" -> Field 2 appears
I'm pretty sure this isn't possible but I just wanted to be 100% sure.
Katarzyna Pawlak March 1, 2018
Hi @Daniel Pasacrita,
I'm from InTENSO. Your problem can be solved by our app: Extension for Jira Service Desk. Thanks to dynamic forms feature you can show fields depending on the previous field. So this is exactly what you need.
Please get a 30-day trial from Marketplace. If you have any questions, don't hesitate to ask our support team.
Best regards,
Katarzyna
Susan Hauth _Jira Queen_
Intenso has a couple of JSD Plugins - Extension for Service Desk and Dynamic Forms that could meet that requirement.  Nothing native in JSD at the moment.
Susan
Nic Brough -Adaptavist-
August 18, 2017
Off-the-shelf, no.
I understand there's an add-on coming soon that will enable it, but I don't know when (probably summit time, as it's that time of the year again)
Let's build A Rovo Agent 🤖
Save your spot
