Is there anyway to see how much time was spent per day?
KasiaCC September 9, 2015
Is there anyway to see how much time was logged for project per day?
Midori
September 10, 2015
Yes.
Export your worklogs to an Excel sheet with the Better Excel Plugin, and create a pivot chart with 2 dimensions (project and day) and one metric "sum of time spent".
In fact, the plugin has two templates that solve 80% of this, and you can achieve the remaining 20% with reconfiguring the pivot tables in those.
Darren Pegg
September 9, 2015
Groovy can also do this for you and display against a custom field and then be used on a dashboard or view issue screen it's a little complex so I'd suggest building a plugin if tempo is over kill. Plus you can't display total time spent per day using tempo against a custom field only via a report (on screen/export).  Though you could use the export function from tempo and use a plugin like nFeed to look at the report and display the data back into JIRA against and custom field..
Pilar
September 9, 2015
Yes, with tempo plugin you can monitor for yourself and for each individual in your team, the amount of time spent  per project.
Here is the link to tempo plugin
https://marketplace.atlassian.com/plugins/is.origo.jira.tempo-plugin
Pilar
