We are trying to use next-gen features in a Jira project which is forcing us to create a new project with these features (https://confluence.atlassian.com/jirasoftwarecloud/migrate-between-next-gen-and-classic-projects-957974933.html)
The problem is the team really wants to use the old project key. But I can't bring it over as stated here (https://confluence.atlassian.com/adminjiraserver080/editing-a-project-key-967897188.html#Editingaprojectkey-Post-updatetasks)
Am I just out of luck here?
Hi Will,
Welcome to the Atlassian Community.
The only way to reuse a project key would be if you delete the existing project. Once you use a project key, it is tied to that project.
Thanks, Mikael for the help!
Hi! I just tried this in Jira Cloud and it didn't work - I deleted the "Erika Demo 2" (key: ED2) project, went to create a new project with the ED2 project key, and it gives an error saying "Project 'Erika Demo 2' uses this project key". I'm wondering if the 60 days in the trash needs to pass before it can be reused?
@Danielle Bonneau No, you do not have to wait 60 days, just go into the trash and delete the project. then you should be able to reuse the key.
@Jeramy If you delete a project in Jira DC it is not moved to trash, it is instantly deleted if I remember correctly.
@[deleted] The project key is logged in the data warehouse. When a project is deleted the key stays in the data warehouse. So you would have to contact the JIRA System administrator to remove the project key from the roster so Jira thinks it is a new key.
@Mikael Sandberg - Thank you for the response. I will double-check because I thought it kept the key in the database, even after deleting the project. Take care.
@Jeramy You are correct, on Jira DC once you used a project key you cannot reuse it unless you delete if from the DB (it's been 3+ years since I was using DC). There is a suggestion to add a feature to be able to do it without doing into the DB and do it, JRASERVER-72112.
Learn more
