For some of JIRA-Enhancements or JIRA-Bug. I want to create a "Story with some subtasks". With the below details
As this needs to be done for multiple JIRA's, manually creating them is becoming time-consuming. Can you please answer the below questions?
Creating 3 sub-task when "Story" issue is created should be fine and assigning these issues to same user could be done through automation rule.
Have few question.
1. Story should have an Epic link or Story should be in Epic level ?
2. You want to create the Story through automation or user's will create story, later sub-task and issue block should happen ?
Thank you very much for the response, please find the answers to your questions.
Q: Story should have an Epic link or Story should be in Epic level ?
Q: You want to create the Story through automation or user's will create story, later sub-task and issue block should happen ?
Warm Regards
J S S S Bharath
Thanks for the info. So a user will create an Epic. Once Epic is created you want story to be created automatically ?. I am trying to understand the trigger point on when the automation should create a story.
Hello @Mohanraj Thangamuthu ,
The trigger for the automation should be "manual", I want to decide if for a JIRA-Bug / Enhancement, the story or sub-tasks are required. And by that time I decide to execute the automation the EPIC would have been created.
To explain you little more:
Warm Regards
J S S S Bharath
Please consider this a gentle reminder..
Do you have any insights on my requirement?
Warm Regards
J S S S Bharath
HI,
It is possible achieve such use cases using Automation rules in Jira.
If you are using Jira cloud, then you can refer this article to learn more on how to use automation rule in Jira: https://support.atlassian.com/cloud-automation/docs/create-and-edit-jira-automation-rules/
Here you can find library of example cases using Automation rules. Automation Library
