When I insert an issue from JIRA into a Confluence post, the link to the JIRA issue goes to a link that has the port 8080 in it.
My instance of JIRA is running on 8443. Is there a way to fix that Issue insert so that it uses the right link?
Graham
Please check your jira's base url in general configurations.
Also, check the configuration of the Application Links, as there is a Display URL field that may also have the setting to the incorrect port*. :)
