Issue Navigator Column Options
jmill June 17, 2013
When I use my issue navigator I see my sub-task column, in that column it shows the issuekey for the sub-task but I want it to show the sub-task name as well, is this possible?
Timothy
June 17, 2013
You may have to change the subtask-columnview.vm file.
jmill June 17, 2013
Timothy
June 18, 2013
What do you have in your file now? And what file did you change?
jmill June 18, 2013
I have not made any changes yet. I didn't know if I could use the above code in the link but modify it for the subtask-columnview.vm file. Not sure what changes would need to be made however as I have never worked with volicity files.
