Issue Navigator won't configure to show a user picker custom field?
Miguel De Dios October 28, 2013
I'm trying to query issues with specific criteria. One of the criteria is a user picker custom field we call 'Responsible Manager' and while configuring columns that field won't display even after adding it to my columns. Other custom fields like a select list custom field called 'Team' does show up however.
Does the Issue Navigator only configure to display certain custom fields? User picker not being one of them?
Any ideas?
RambanamP
October 28, 2013
check this jira KB doc
https://confluence.atlassian.com/display/JIRAKB/Custom+Field+Column+not+Visible+in+Issue+Navigator
and also check this
https://answers.atlassian.com/questions/175288/custom-field-value-not-visible-in-issue-navigator
The workaround listed in that document did the trick. Thank you!!
darylchuah
October 28, 2013
Hi Miguel
Nope you can still configure the custom field type user picker related in the issue navigator and it should be something like the following (JQL):
Responsible Manager in (admin)
Upcoming Jira Events
