Issue Security Level
Hanae alahcen
hello,
can i know how to display the "security level " in the issue's informations ?
Because when a user creates an issue in the same project
Sometimes we see the level of security Sometimes we don't
[pic]
https://docs.google.com/file/d/0Bx2sOasGvzxtUG42OW1pV2tDUVU/edit
Thanks for your help
Udo Brand
July 30, 2013
I guess, you see the security level field only if you got the permission "Set Issue Security". Please check your permission scheme, if this fits with your observation.
Deleted user May 27, 2020
We are determining a approach to restrict few set of users to view a Issue Type in JIRA Project. We have a plugin called "Issue Type Filter Security" with which we can restrict some set of users to create that Issue Type but we want them not to view, search, browse or query that Issue Type.
We tried the Issue Security scheme approach where we have created a security level and used the group and group custom field value attributes. So ideally by applying this scheme only those issues which are having that custom field should be restricted but we found that all the other Issue Types are getting restricted, If we are creating any other issue type then we are not able to view it after Creation.
We just wanted to know a approach where we can restrict some set of users to browse, view , edit, search a particular type of Issue.
Kindly suggest how can we achieve this. We will wait for your response.
JIRA_USER September 1, 2016
I have similar issue but the not the exact.
I have setup the security level for a bug if a field Customer = Yes, then User under QA group cannot see that bug. which is fine and as expected.
But the issue is that, I created a bug and i Have Customer - No, and I submit the bug. Now I realize that it should be as Customer = Yes. and I updated the bug in View/Edit screen. Now, I expect to have this bug to be in security level which means should not be visible to QA group users and the bug should display Security level message. But its not happening.
Could anyone advice me please?
Please let me know have any questions?
JIRA_USER
Nic Brough -Adaptavist-
July 30, 2013
I'm sorry, I forgot. I have a feeling that you can only see levels of which you are a member.
Let us say you have security levels A, B and C
You set level A on an issue
User Alice is in the groups that are named in A and B, and Bob is in groups that give him B and C.
Alice will see level A on the issue because that's what is set, and she's part of A
Bob will not see level A on the issue because he can only see the issue because he's part of B
(I'm really not sure - I haven't used security levels enough to know, but I suspect this might be what's happening)
July 30, 2013
Ach, no, ignore me - Bob won't see the issue at all, he's not in A.
I think you need to establish an exact pattern for this behaviour. Concentrate on one issue, with one security level and then find two users - one who can see it, and one who can't. Then look at the differences between them. What security levels can they see? And also - do the users have rights to set the security levels? (Bearing in mind you can only set a security level which you belong to - I think that's what made me think about the answer above)
Edit - argh, tied myself in knots again and missed out one thought. If the issue is set to level B, then Bob will see the issue, and level B written on it. If Bob then tries to change it, he will only be offered B and C because he's not in A. I think. (I think I need more coffee and a little holiday, before my brain explodes)
July 30, 2013
What's the difference between the issues you can see the level on and the ones you can't? Different security levels?
Hanae alahcen
i know what you're talking about , i'm talking as an administrator
it's misterious
i created some issues myself once i can see the security level displayed once it's not :s
Hanae alahcen
because the gadget on the dashbord can diplay issues filters by Security level this information is important for me to be showed
July 30, 2013
Ah, ok. Remember that if a user cannot see an issue (because of the project permissions or the security level), then it is NOT reported to them in any way.
A simple example: You have the security example I wrote up before. You've got a project with 15 issues, 1 with no security level, 2 with A, 4 with B and 8 with C. You have a filter for "all issues in project"
So you add a gadget on a shared dashboard for "filter statistics, grouped by security level", and pointed at your filter for all issues in the project.
When Alice visits, it will say none: 1, A:2 and B:4
When Bob visits, it will say none: 1, B:4, C:8
When you, the admin (who you have included in all security levels) visits, you'll get the full story because you can see all issues.
Hi Nic Brough [Adaptavist]
JIRA_USER
September 1, 2016
Your field has nothing to do with the security level.
JIRA_USER September 2, 2016
I made Security Levele field Visible in the Edit Screen. That will work to some extend to put the security level in a bug. But, I want the to make as when I select Customer = Yes in Edit screen the Security Level (Default Field) should changed to be required field and also Should Default to Security Level Value. Could you please help me on this?
Thanks in Advance.
September 2, 2016
You will need to find/write code that can set the security level when your field is set.
I am new to JIRA and below is my 1st grovy script which I wrote to meet my requirement but its not working. I am editing the defect in Edit screen and I expect to be the security Level field to be required and default to the value (Group security).
def Cust = getFieldByName("Customer")
def security= getFieldByName("Security Level")
if (Cust.getFormValue() == 'Yes') {
security.setFormValue("Group security")
security.setRequired(true) }
else {
//security.setHidden(true) // hide any fields you like
 security.setRequired(false) }
Please advice.
September 2, 2016
That looks like a front-end script of some sort.  It's not going to work, you need to set it in the back end, as a post-function.
Yes, this script is in Behaviours. Could you please help to take this issue to the resolution?
JIRA_USER
September 2, 2016
It won't work with a Behaviour because only people who are part of a security level can set it.
You had roughly the right idea, but you need a scripted listener that will listen out for any issue update where a user might set the customer field, read the change and then set the new security level as appropriate.
JIRA_USER September 6, 2016
Hi Nic Brough [Adaptavist],
Thanks for your continuous support and effort.
I’m still on a roadblock with the issue.
Here are approach and roadblock.
1st, I created a Issue Security Scheme and Security Level then assign group to the security Scheme/level so that user within the group can View / access the bug. And I wrote a post function condition, so that if the field Customer = Yes, this bug will only be visible to the user within the group added in security level. This is working fine, if I submit the bug with Customer = Yes in each transitions. No issues.
But, the issue is that if I submitted a bug with Customer = No in my create screen and later I decided to update Customer = Yes from No in any status/transition then the security level is not working as expected. Once the Customer is updated from No to Yes, this should only be visible to the user within the group added in security level.
So, I enable the Security Level field (Default field) in Edit screen. Now, I update Customer to Yes from No (manually). Then Security Level field should Default to the "Security level value" or should be changed to the required field. Again, this is not happening. I can change Security level field value and make the bug only visible/accessible to the user within the group added in security level. But, I do want to have Security Level field as required and default to the value, automatically. So that no user will skip the value in field and I can restrict certain user viewing/accessing the bug.
Please advice.
JIRA_USER
September 6, 2016
I added my Custom field Customer in Behaviours and added the script in script listener as below but it did not work.
else {
September 6, 2016
Again, Behaviours will not help you.  It acts on the screen, and your users will only have the field there in certain cases, so it's not going to do anything.
That doesn't look like listener code.  There's no forms in listeners.
I know I am not doing right. I am very new to JIRA world. So not sure what to research and I do not know anything about the groovy script.
Could you please help me with my requirement or direct me some extend if Behaviour wont help at all?
September 6, 2016
yes, I have listner inplaced i Post function as given in the Adaptavist Scipt Runner but its not firing when I update the Field (Customer with value Yes from No). Its only working when a bug is moving via transition.
Restricting access to an issue
When creating (or editing) an issue, you can restrict access to that issue to members of your team who are part of a chosen security level. To be able to set the security level for an issue, your administrator must add you to the appropriate issue security level, and also grant you the 'Set Issue Security' permission for the appropriate projects.
  1. Create/edit the relevant issue.
  2. In the Security Level drop-down field, select the desired security level for the issue. You will only see the security levels you belong to.
  3. Save the issue. It is now only accessible to members of the specified security level. Users who are not members of this security level will not be able to access that issue, or see it in any filters, queries, or statistics.
As per the note in confluence page, it is saying created/edit - Here im editing a field (Customer) from No to Yes so I can choose Security level field value, but If I edit Customer  field the security Level should be a required field.
September 6, 2016
That is a post-function, not a listener.  I'm not sure why you are wandering off to do other things, when I specifically said "listener".
Now, a post-function could do the job, but I've suggested a listener because you want to do things when editing as well, and there are no post-functions there.
And, on your last comment, yes, that's what I said.  You need a listener to pick up the edit of Customer and set the security field.
JIRA_USER September 7, 2016
I finally achive the solution that I was expecting. Thanks for your hints.
RambanamP
July 30, 2013
Hanae alahcen
But i never set the security level while creating an issue , for other groups ( with another security level ) it's showed automaticly
but for this new group somtimes it's shown sometimes it's not
July 30, 2013
You will only see the field if you've got a security scheme associated with the project, AND a security level is set on the issue.
If it's not showing, then there is nothing set for this issue.
RambanamP
July 30, 2013
@Nick, they have set the security scheme because she can able to see that on one issue and not able to se on another issue bothe issue related to the same project
i am wrong?
July 30, 2013
If it's not there, then the security level has not been set.
Atif324 July 1, 2019
How can we then add security level to the exisiting issues?
July 1, 2019
Edit the issue, selecting a level on the edit screen.
In Edit Issue, the security level field is not present
July 1, 2019
You need to add the level field to the screen, make sure you have an issue security scheme associated in the project settings, and that the person trying to edit it has "set security" permission and is in one or more of the levels.
I got it, I have already added the security level scheme to the project as well as I am in the security level as well. The level field don't show in the screen either
Like • vedyilmaz likes this
July 1, 2019
So the account does not have "set issue security" permission, or is not in any security levels.
Amy Martin July 3, 2019
I'm in the same boat. We can only view the Security field upon creation of an issue. Once saved the field disappears, although I can bulk change the field. The security scheme works, but we can't access the field all but when we first create the issue. I also cannot find or add it with "Configure Fields". It's just not there. It's there to bulk change, it's there when first creating an issue, and then it isn't there any other time.
  • Permissions Scheme includes Set Issue Security for all needed project roles
  • Security Scheme has been created and is associated with the project
  • Security field is on all needed page layouts
We'd like to be able to view the issue permission on the issue, and we'd like to be able to change the issue permission at any time from the issue edit screen. What am I missing or is this a bug?
July 3, 2019
Could you create a test issue, selecting a security level for it.  Go do something else (there's a minor bug I've seen where a field disappears if you go straight into the issue view) then go back to the plain issue view, ideally using the url direct  (https://yourjira/browse/ABC-123)
Click "edit" to get into the edit screen for it, and then use "where is my field" from the "configure fields" option to look for "level"?  That will tell you why you can't see it on the edit screen.
Thanks for the response and further problem-solving - here's what I found out: If I flip the view to the "old issue view" - I can see the security field, edit, etc. It's just not anywhere to be found in the new issue view. Think this may be a bug/roadmap issue or is it something I'm missing for the new view? At least I found a workaround!
July 3, 2019
Ah, I completely forgot - security does not apply in the new issue view, nothing has been implemented for it.  The level should not even appear when creating an issue.
Surprise! It appears when creating an issue in the new view. At least I know I'm not crazy. Thanks again for your help.
July 3, 2019
I am really sorry that I forgot to ask about the new view.
It is missing so much stuff I have been working with for the last 15 years, and take for granted now.
You are definitely not crazy, I am a bit surprised that Jira has managed to suggest that you can use issue security in the new view when you can't (yet), and I apologise for not thinking of that!
[]D []-[] [] []_
Hi for example the fieldconfiguration and display-screen have to contain the Field 'securitylevel'. Also the field must have a value.. try to use "where is my field?"-function?!
