I'm trying to create a gadget that shows the number of issues for a set of labels. I created a filter with:
labels in("label A", "label B")
and then created an Issue Statistics gadets with "Label" as the statistic type. The problem is we have over 500 labels and it's showing every label. Is there any way to only show the labels that are specified in my filter?
I would love to hear an answer for this too.
Hi Chris,
I just tested this and I have three issues, two with a label that say bluel and one that says red.
I created a saved filter with a search for
labels in red
I created an issue filter gadget and in the first box that says project/issue filter I searched for the saved filter I created and it only showed the issues that have the label for red.
I did not try creating the gadget without a filter but you may want to try editing the gadget to see if you can add a filter if you did not previously.
Branden
HI Branden. Thanks for the response...sorry for the delay in responding. I think the difference between what you're doing and what I'm doing is I'm using the "Issue Statistics" gadget...not the "Issue Filter" gadget.
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
