Hi.
I'm trying to Add an existing workflow to a project. During the step "Publishing workflow scheme " I receive the error
WORKFLOW ASSOCIATION ERROR
There are errors associated with issues that are to be migrated to the new workflow association.
These errors must be corrected before the workflow association can be completed.
No changes have been made to the database.
Errors
Unable to determine the current issue type for issue 'XXXXXXXX'.
When I tryed to search for the issues on the error I get error 500:
java.lang.IllegalArgumentException: Issue Type for issue with id '426508' is null.
I have run the integrity checker with no luck.
Any suggestions?
Ouch, that sounds like one of those times when something goes bang in the middle of an update and there's nothing you can do (the apocryphal story about the cleaner pulling out the plug so they can run the hoover, just as one of your users clicked on an issue edit)
I usually avoid it, but I think you may want to update the database. Take JIRA offline before you do this, but
select * from jiraissue where issuetype = null
check all the returned issues are your XXXXXX ones
update jiraissue set issuetype = 1 where issuetype = null
You might want a different number - I've picked 1 to set them all to the default in JIRA, but you should use a valid id from your issuetype table.
Once you've run that, restart JIRA, and re-index the project the issue was in (or projects).
There is a subtle difference on a null check for some databases. If you are backed with a postgreSQL database you may need to use a different form of the queries :
select * from jiraissue where issuetype is null;
update jiraissue set issuetype = 1 where issuetype is null;
Register today
