When you create an issue, you can choose the wheel ('All' or 'Private') in order to display field in the issue creation field.
But, when i choose private and select fields, if i quit Jira, when i coming back, all selected field are not displayed, i have to do it again.
I think i miss something...
Thans in advance to help me !
I'm not sure I understand this "all" or "private" thing - could you explain? It sounds like it might be a plugin of some sort.
Hi Nick,
No, in fact in jira 6.0x when you create an issue, in the issue creation screen, you can choose a configuration option to display some fields.
My instance is in french, so i do not have the real term, but i can choose personel settings and i select (checkbox) field i want to display, that is great. The thing is that i want to keep this setup for the next connexion, and here, it is not working like thaht, i have to enter again and checl again the field.. Hope to be clear, thanks a lot !
Ah, I see, the configuration option with show and hide ("private" implies some form of security and hiding from other people, which confused me. Sorry)
That behaviour sounds odd to me - my Jira remembers my chosen fields. Are you doing anything like clearing cookies out when you close the browser?
No problem - glad you found a solution!
Register today
