Issue in custom script
Fadi Shahwan November 14, 2024
Hello Everyone
I'm using Jira DC v 8.22.2 and Im trying to achieve some requirements using script runner.
The script will update the Progress% of the "Demand" issue type based on the "Weight" and "Progress%" of the "milestone" sub tasks. However, I'm facing error (unable to resolve class) in  import com.atlassian.jira.issue.fields.CustomFieldManager
any idea about this error ?
2 accepted
Hi @Bobby Bailey
sure, HYG
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.util.IssueChangeHolder
// Get the current issue (demand)
Issue issue = issueManager.getIssueObject("ISSUE-KEY") // Replace with the actual issue key
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
// Get sub-tasks
def subTasks = issue.getSubTaskObjects()
def totalWeight = 0
def weightedProgress = 0
subTasks.each { subTask ->
    def progress = subTask.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("progress%")) ?: 0
    def weight = subTask.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("weight")) ?: 0
    if (weight > 0) {
        weightedProgress += (progress * weight)
        totalWeight += weight
// Calculate the final progress%
def finalProgress = totalWeight > 0 ? (weightedProgress / totalWeight) : 0
// Update the demand issue's progress%
def progressField = customFieldManager.getCustomFieldObjectByName("progress%")
issue.setCustomFieldValue(progressField, finalProgress)
// Save the changes
IssueChangeHolder changeHolder = new DefaultIssueChangeHolder()
issue.store() // Persist changes
Bobby Bailey
November 14, 2024
Awesome, thank you!
So, to answer your initial question, the reason this was failing is because the import line is:
import com.atlassian.jira.issue.CustomFieldManager
Rather than
But once I fixed that there were other issues with the script, and we can solve all of those and make it easier to write and read using HAPI. So, if I rewrite this script in HAPI:
def issue = Issues.getByKey('WEB-8') // Replace with the actual issue key
// Get sub-tasks
def issueSubtasks = issue.getSubTaskObjects()
def totalWeight = 0
issueSubtasks.each { subtask ->
    def progress = subtask.getCustomFieldValue('progress%') ?: 0
    def weight = subtask.getCustomFieldValue('weight') ?: 0
    if(weight > 0){
issue.update {
    setCustomFieldValue('progress%', finalProgress)
Could you give this a try and let me know how you get on please?
Bobby
Thanks for your support Bobby, i got one error related to the field name "Progress %"
Could you check and advice
Bobby Bailey
November 14, 2024
Apologies, it looks like to update a number field you need to pass a string! (No idea why)
So this:
setCustomFieldValue('Custom Number Field', finalProgress)
becomes this:
setCustomFieldValue('Custom Number Field', finalProgress.toString())
Could you try this and let me know? And in the meantime I will try to find out why that is the case.
Bobby
Perfect! it is working fine ;)
Thanks a lot Bobby
Bobby Bailey
November 14, 2024
Hi @Fadi Shahwan ,
Are you able to share your script? It would make it much easier to see what the problem might be :-)
Bobby
SERVER
VERSION
8.22.2
