Issue priorities per project
Pascal Collard November 2, 2011
Hi;
I'm looking to create issues priorities list to be per project so I would have something like:
  • project 01
    • Blocker
    • Minor
  • project 02
    • P0
    • P1
    • P2
  • etc
I know how to create priorities but can't figure out how to assign specific options for specific projects.
Fabrizio Galletti
November 2, 2011
It't the most popular issue on atlassian jira support site.
https://jira.atlassian.com/browse/JRA-3821
Voted for it
Jeremiah Landi
Looked into this and here is a summary of items I am posting to all the tickets I found. Hopes this helps in the future! Please upvote the open ticket.
- JIRA - custom priority options for a single project (https://goo.gl/wWJRd8)
- Custom priority per project (https://goo.gl/4kP6RG)
- How to set custom priority for a new project? (https://goo.gl/J8jNnP)
- Issue priorities per project (https://goo.gl/uqoPFA)
- How do I customize priority list for project (https://goo.gl/aun5vc)
- is it possible to define a custom priority for the project? (https://goo.gl/Wf36HE
-Default priority - specific to a project? (https://goo.gl/qJExIM)
**** Open Ticket (and @Nic Brough favorite ticket) JIRA: JRASERVER-3821 Priorities per Project and Resolutions per Issue Type (https://goo.gl/5CKTS1)
Fabrizio Galletti
November 2, 2011
It's the first popolar issue on atlassian site.
Katlego Masanabo June 20, 2018
there is another way you can do it, just applied it yesterday as i was having the same problem. let me know if you haven't figured it out yet.
Nic Brough -Adaptavist-
June 22, 2018
Make sure you are on Jira Server 7.6(ish) or above?
Support [Develocenter] February 11, 2016
Hi all,
you can try Extended Schemes for JIRA. It provides Priority Schemes exactly as you expected. It allows to configure list of priorities for project and/or for issue type. Add-on also includes schemes for Resolutions and Link Types. Additionally you can provide default value for each scheme. I hope it will be useful for you.
Jobin Kuruvilla [Adaptavist]
November 2, 2011
It is not possible at the moment. You will have to modify the velocity templates to handle this or hack it in Javascript or something!
November 2, 2011
Sounds good ;)
Thank you Jobin, 3rd option would be to not change the list at all :)
Raju Adluru
October 3, 2014
Jobin, any idea which velocity templates file need to be changed, we want to implement this change, or if you have any javascript which can do this.
Register now
