HI,
I need to change the status field, when i create the issue through REST API. But i can't set the value for status when i create the issue.
Please explain the steps to enabling the status field in issue create screen.
Hi there,
According to: https://answers.atlassian.com/questions/154568/jira-json-create-issue-with-status-resolved
The JIRA JSON Importer can set the resolution field in issues that it imports. But usually the resolution field (not Resolved) is not on the edit or create screen for an issue (and it should not be there). You could create the issue and then change the status using the appropriate REST method. More information athttps://answers.atlassian.com/questions/107630/jira-how-to-change-issue-status-via-rest
When an issue is created, its initial status is determined by the workflow and workflow scheme associated with the project. To move the issue to a different status, you need to take the issue through a workflow transition.
