Sign up Log in
Issue type: Sub-task mysteriously converted/promoted to a standard type.
Brent Webster
September 19, 2017
So I'm not talking about individual issues being converted but the actual Sub-task issue type now shows up as a standard issue type.  I'm working with a new customer and novice admins so I'm not sure how it happened.   It is a relatively new setup so no subtasks are currently created.   Is is safe to delete and then recreate the Sub-task?  Is there anything hardcoded to that Sub-task class/id?
Alex Koxaras _Relational_
April 23, 2023
Hi @Brent Webster
You can't simply promote a subtask to be a standard issue type. Someone could rename the old subtask and have created a new standard task with the same name. And most likely moved all issues to the new task.
I would recommend for you to create a new subtask with you name of your liking, and move then back to being a subtask. However, the most difficult task will be to find out which the parent task was.
How many tickets are there?
