Sign up Log in
Issue type name changes once it's selected
Michelle Greenfield December 11, 2019
I created a new issue type and initially called it "Test Electronic Processing".  When I finished creating it, I changed the name to "Electronic Processing New".  It appears with the correct name in most cases except when you select it from the Create button, the name changes back to the old name while you're recording data under that issue type.  Is this a bug?
Kirstin Seidel-Gebert
December 11, 2019
Hi Michelle,
could this be a problem that can be fixed by reindexing JIRA?
Kirstin
Michelle Greenfield December 12, 2019
Thanks. I have only been able to reindex when I've been given the option to do it.  I don't know how to do it, otherwise. Can you please give me instructions on how to do it? I'm a real novice at this and learning as I go.
December 13, 2019
  • Press the "." key. You should get a small pop-up where you can enter text.
  • Start typing "Indexing". A list of actions filters as you type.
  • Select Indexing.
  • Provide the admin credentials if necessary.
The indexing page is displayed. Option Background re-index is selected.
Read the explanations of the options. I nearly always use background re-index but note that re-indexing affects the performance of your instance. You might want to do this in in off-peak periods.
  • Click Re-Index to start the indexing process.
Kirstin
Michelle Greenfield December 16, 2019
Thank you for your advice.  Unfortunately, this has not solved the issue. Any other suggestions?
December 16, 2019
No, sorry.
