×I'm trying to do a manual upgrade as recommended by the docs. I've copied my osusers.xml file and when I start Jira to upgrade the data I get:
Exception thrown during upgrade: org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03151EFD, problem 2001 (NO_OBJECT), data 0, best match of
I've seen that using
< property name = "java.naming.referral" >follow</ property >" has worked for some. Although I am using a Global Catalog in order not to do forwarding/referals for multiple sub domains that arn't accessable from the jira server. wondering if anyone has any ideas how to get the upgrader to like my ldap setup?
TIA
Basically your issue is caused by a non-existent DN specified in the User Search field, so oou may be asked to define a DN so that a service can bind to it to authenticate.
Hi Paul,
There is a KB for this issue, please refer here.
Hope it helps.
John
can you please provide a little bigger part of log?
