Issue with auto calculate percentage done.
Deleted user March 24, 2022
When looking on a WBS Gantt the "Percentage Done" on the Epic (parent issue) seems to be 0% although the Children's are on 100% .
Using Auto calculate "Percent done" in the "User Preferences".
Seems like a Bug, when I click on "Outdent" it seems to be filled with the correct data, then on refresh it's going back to 0%.
Please advise.
Yasuhiro Kawamura -Ricksoft- March 25, 2022
Hello @[deleted] ,
Are you using "Use specific field" for the progress rate setting of Epic?
If you are using "Calculate with time tracking automatically" or "Calculate with specific fields automatically", the progress rate of the child issues will not be reflected in the progress rate of the parent issue.
Issue view setting
Kind Regards,
Yasuhiro Kawamura
Ricksoft, Inc.
Deleted user March 28, 2022
Hi @Yasuhiro Kawamura -Ricksoft- ,
Thanks for your answer.
Register today
