Issues which changed type recently
Jan_Marcinkiewicz February 12, 2020
As I am completely new to Script Runner, may I ask you for help with starting Script Runner preparation for getting all issues that changed type from one particular to another particular?
I found some examples but I stuck on pretty basic things like not matching methods such as getAllChangeItems(issue).
Could you please direct me to where to look for beginner steps or some actually working examples?
Leonard Chew
February 12, 2020
I dont think you can query your desired issues directly with the built-in JQL functions of scriptrunner, so you'll need to script something.
I know this is not the desired working example you are looking for, but still, here is an idea to achieve your goal:
  • create two custom fields:
    1) Issue Moved Date (Date Field)
    2) Old Issuetype (Single Line Text Field)
  • Create a Script Listener that listens on the "moved issue" event.
    The listener would populate the two fields with the corresponding values (at event time).
  • Now you can query your issues on the two new fields:
    "Issue Moved Date" > -7d and "Old Issuetype"is not EMPTY
