×Hi Everyone,
We are seeing below issue while importing Mysql 5.6 XML backup to Postgres 9.6. in JIRA 7.12.3. We are using AWS RDS instances. Already used XML cleaner to clean backups before import.
com.atlassian.activeobjects.internal.ActiveObjectsSqlException: There was a SQL exception thrown by the Active Objects library:
Database:
- name:PostgreSQL
- version:9.6.9
- minor version:6
- major version:9
Driver:
- name:PostgreSQL Native Driver
- version:PostgreSQL 9.4.1212
org.postgresql.util.PSQLException: ERROR: relation "public.AO_455C86_PASS_POLICY_PROP" does not exist
Position: 32
Database:
- name:PostgreSQL
- version:9.6.9
- minor version:6
- major version:9
Driver:
Position: 32
TIA!!
@Thomas Deiler Thanks for your reply XML back is on JIRA 7.12.3.
we are switching database in the new instance.
Since MySQL RDS is not supported by Atlassian.
Ok, then something went wrong when exporting the data. The XML dump is free of any DB flavour. It would make no sense to export DB details in an XML file. Otherwise you could just dump the DB without Jira.
Just to double check - when you reimport into the same DB type, does the error occure, too?
Another source of the error: Have you set up postgresql like recommended by Atlassian?
Why does the driver say its version 9.4.1212 and not 9.6.9? Are there parallel DB versions installed?
So long
Thomas
Re-Importing to the same XML to the same DB worked fine.
Another source of the error: Have you set up PostgreSQL like recommended by Atlassian?
We are using RDS Postgres and DB has been created instruction given by atlassian.
Using 9.4 JDBC is atlassian recommendation.
"Jira is tested and bundled with the 9.4 JDBC driver. You can also use the latest JDBC driver for your PostgreSQL version, though we can't guarantee it will work with your version of Jira."
Can you be more specific on this question,
"Are there parallel DB versions installed?"
TIA!!
Dear @Ash,
it's possible to manually install more than one DB of the same type on one system. My thought was, that there are two different versions installed. But you exclueded this.
Then lets check your process for the migration (my assumtion):
So long
Thomas
@Thomas Deiler Thank you so much for your responses.
Yes, we followed the same exact steps.
Did you use the same JIRA_HOME as with the old DB?
we copied these two folders to our new server.
/var/atlassian/application-data/jira/data
/var/atlassian/application-data/jira/plugins
Try this:
so long
Thomas
@Thomas Deiler Thank you.Will try this.
Hello @Ash
Did the steps provided by @Thomas Deiler work for you?
I am facing almost the same issue as you, although with the relation "public.AO_7DEABF_EXEC_CLUSTER_MESSAGE".
Hi @Contact IT did you try these steps ??
https://confluence.atlassian.com/jirakb/how-to-handle-4-byte-characters-in-xml-backup-899181755.html
There is an issue with xml cleaner.
