×Hi All, Ideally the issues which do not have any value on the "Sprint" field should come under "Backlog" on the Sprint Board, Recently i migrated some issues to a different JIRA project and then moved them back to the same project. Now, the backlog column is empty on my sprint board. Is there something i am missing?
You're saying a backlog "column", but I'll assume you're talking of the Backlog tab and not a column in the Active Sprints tab.
There could be 2 reasons your issues do not show in your board:
The quickest way to find out is to run a JQL query using the board's filter. If your issues aren't there, it's #1. If they're present, it's likely #2.
Opening the detailed view of one of these issues will confirm #2: you'll see a sprint in the Sprint field. You'll also have the sprint report in the board's Report tab.
