We can perform following task , if the sync is possible.
- Management of access log / license of Jira.
- Synchronization of 365 account and JIRA Account.
- Single Sign On used for 365 Account
Hi @Sys
With Kantega SSO, you also get SSO with Office 365 (https://docs.kantega.no/display/KA/Azure+AD).
In addition our add-on allow you to administrate users and their group memberships (permissions) in the Azure only. By setting up our Azure cloud connector, Jira will automatically be updated and synchronized in the background.
Please notify us at atlassian.support@kantega.no if you have any questions or need a screen sharing session to set things up perfectly.
Produkt link: https://marketplace.atlassian.com/apps/1211923/jira-single-sign-on-sso-saml-kerberos?hosting=server&tab=overview
Jon Espen
Hi @Sys Admin,
on Jira Server what you like to do is possible with our plugin - https://marketplace.atlassian.com/apps/1212130/saml-single-sign-on-sso-jira-saml-sso?hosting=server&tab=overview
It's actually exactly the setup we use internally for our company as well.
With the Setup Guide residing here: https://wiki.resolution.de/doc/saml-sso/latest/all/setup-guides-for-jira-saml-sso/setup-saml-sso-with-azure-ad-jira
Christian
Hi, it should be possible to use SSO from Office365, it is explained in an earlier question that you can find here: https://community.atlassian.com/t5/Jira-questions/Login-to-JIRA-through-Office365-SSO/qaq-p/686982
Register now
