It would be really helpful if the Jira number shows when a subtask is created so I don’t have to go
Orazio Pensabene February 19, 2019
Maksim Smetannikov
February 19, 2019 edited
on that table Jira.table.cols.subtasks I have issuetype, status, assignee, progress. cant find what to put for the number to show...
Ben Poulson
February 19, 2019
@Orazio Pensabene
Try adding key
key is not valid
Maksim Smetannikov
February 19, 2019
issuekey
Like Orazio Pensabene likes this
Orazio Pensabene February 21, 2019
After reading the reply it was funny because I knew the name but it did not register, so I now see it on the screen but not in front of the name... appreciate the community...
Maksim Smetannikov
February 21, 2019
Unfortunately, you cannot change the sorting of these columns. Showing issueKey is all you can do in this case.
___
For the sake of reorder columns, you can try to rebuild the Jira application from the source code by changing this class:
WEB-INF/classes/com/atlassian/jira/web/component/TableLayoutFactory.class
But I think it is a long and unjustified way))
___
Thank
