×Is there a way to trigger a prepopulate description field with a template, based on the choice from a drop down list?
Example:
Dropdown list has options A - C.
If A is chosen, it will show template A.
If B is chosen , it will show template B.
etc
Thinking right now my only option is an addon with JS.
You would need an add-on for it. For example, you could use the Power Scripts add-on:
There is a feature, called Live Fields, which will let you do what you want.
Thanks! Do you know how I would call a Jeditor Template in a script for this?
Do you mean Jeditor from the JEditor - Rich Text Editor for Jira plugin? If so, not sure. I never worked with this plugin.
Correct. When I reference a template, I mean a specific html setup within the description field.
