JIRA 5.0.6: Error in attach screenshot
shampa
February 12, 2013
What is the attached error suggesting..Thanks.
Immanuel Siagian
February 12, 2013
This is actually a bug, which has been solved on the latest JIRA version (5.2.6). You may view the bug report from here: https://jira.atlassian.com/browse/JRA-31345
shampa
February 25, 2013
Hi Immanuel
What does it take to ugrade to JIRA.
We are using enterprise JIRA 5.0.6
Immanuel Siagian
February 26, 2013
Hi Shampa,
There are many factors to consider upon upgrading, such as whether JIRA will be upgraded on the same machine, the type of distribution (EAR/WAR or standalone) and etc.
The complete documentation for upgrading can be found on this link: https://confluence.atlassian.com/display/JIRA052/Upgrading+JIRA.
Also, it is recommended to test the upgrade before proceeding with upgrading on the production installation.
Hope this helps.
shampa
February 26, 2013
Link says page not found or no permissions
Immanuel Siagian
February 26, 2013
Oops sorry, I have mistakenly added a period at the end of the URL. This is the exact link: https://confluence.atlassian.com/display/JIRA052/Upgrading+JIRA
3 votes
Naren
February 12, 2013
Refer the Certificate Error in JIRA Screenshot Applet knowledgebase article. Hope the workaround mentioned solves your problem.
Immanuel Siagian
February 26, 2013
Vishnukumar Vasudevan
It says the SSL you are using is Self Signed. Not from public ( valid ) SSL provider.
You may avoid the warning or download and install the SSL on your local machine, will solve the issue.
