JIRA 5.2.10 -Title Displays Wonky
Shelli
I just upgraded my lab JIRA from 4.4.5 to 5.2.10 and my title displays wonky as in the below screenshot. Can this be fixed?
EDIT: Apparently the screenshot can only be viewed in edit mode. Basically, the string set in Administration | System | General Configuration | Settings | Title which is displayed at the top of JIRA header bar (same as user name logged in widget) has each word displayed on a separate line and is being hidden by the other page widgets.
Ivan Tse
April 15, 2013
Can you try and select the contents of the entire field and clear it? I want to see if there might be any hidden characters in the field. Can you upload the screenshot to http://imgur.com/ so we can see what it looks like?
Shelli
Hi, I changed the title to "Test" (not allowed to leave it null). Then I set it up to "Our Lab Test JIRA Install" and it displays like:
Our Lab
Test
JIRA
Install
Sorry, but I can't upload to imgur.
