JIRA 6.2: How to use inactive users in user picker field?
Todor Kostadinov
I'm using group picker field as a starting point for extracting information from jira DB ( custom table with Active Directory information ) thru Kepler database custom field.
But after upgrade to 6.2 ( from 5.2.4 ) when I try to use user which is marked as inactive in our AD ( LDAP ), I receive message: "User '******' is not valid for this user picker.
The information is extracted and the Kepler DBCF are filed with info from our jira DB, but I'm not able to create the issue with this inactive user in the user picker field.
Any way to use inactive users in jira user picker field?
Steve Cagle
March 2, 2015
We, too, would like to be able to use the user picker to be able to assign custom fields to inactive users for reporting purposes.  If I start typing in active users it pulls up suggestions.  It doesn't for inactive users.  But if I type in the inactive user's account name, I can still use their name.  So the ability for the user picker to "see" inactive users is there.  It just doesn't auto suggest them.
Boris Georgiev [Appfire]
April 23, 2014
First - why would you want to use inactive users.
I think you'll not be able to do much with inactive users as JIRA denies using inactive users anywhere. This also might be related to the fact that the inactive user does not count for the number of users used for the current JIRA license.
https://confluence.atlassian.com/display/JIRA/Managing+Users#ManagingUsers-Deactivatingauser
Scott Ellis
July 20, 2014
We also relied on the user picker to allow inactive users in selections
Todor Kostadinov
I can't find working solution, so I'll close this question.
Jason Young
February 12, 2020
@Todor Kostadinov I believe closing the question is misleading; please reopen if you can.
Todor Kostadinov
Sorry, I can't find a way to reopen the question.
Todor Kostadinov
Anyone?
Todor Kostadinov
Hi Boris,
the reason we want to use inactive users - we have multiple outside contractors who need AD samaccount in order to access others systems, but not the AD itself. Thats why these kind of users are created and instantly marked with inactive flag. And we need to extract all the possible info about users, even for inactive ones.
Hi Florin,
it is not true that only users that can login can be used in user picker. I saw that the most of the people have asked for the opositive option, but why it is not a configurable option?!?
Florin Manaila
April 23, 2014
Hi Todor,
AFAIK JIRA 6.2 only allows users which can log in in user pickers. Contrary to your request, people have asked to remove this behavior https://jira.atlassian.com/browse/JRA-30412Also see the linked issue for a full discussion on limited user pickers.
As a side note, I don't see a connection to the DBCF plugin you mention in your question or the Kepler Custom Fields plugin you tagged in the question. Am I missing something?
Register now
