JIRA 6.4.14 - enabling SSL and integration with Fisheye/Crucible, Stash, Confluence
Rafal Sojka
I have four Atlassian products under my care : JIRA, Fisheye/Crucible, Stash and Confluence. All of them uses HTTP and I would like to enable HTTPS on JIRA only for now. Do you know what should be modified in F/C, Stash and Confluence to make it working with this new HTTPS-enabled JIRA ? I planned to modified links to JIRA User Server and application links in them.  I wonder if there is something I missed.
Thank you for any suggestions.
Marcos Sanchez
October 5, 2017
I've done something like this before and I had problems with the certificates. This caused me problems when configuring the application links.
You have to install the cacerts of the SSL in the instances of F/C, Bitbucket (Stash) and Confluence.
This links can be helpful to install the cacerts:
If you are using RedHat -> https://access.redhat.com/solutions/1519813
If you are using Debian/Ubuntu -> https://www.brightbox.com/blog/2014/03/04/add-cacert-ubuntu-debian/
If you are using Windows -> https://docs.microsoft.com/en-us/azure/java-add-certificate-ca-store
Rafal Sojka
ThankYou
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
