When a user edits a filter in advanced mode and changes filter criteria using the syntax prompter the remaining portion of the query after the edit is blanked out.
Screen shots below.
Is this a known issue in JIRA 7.8.4?
Thank you.
Debbie
Yes it's a known issue you can may be vote for it here
https://jira.atlassian.com/plugins/servlet/mobile#issue/JRASERVER-65022
Hope this helps
Mohamed,
Thank you for the info. I will follow the issue.
