I am doing a fresh installation of jIRA 7.8 on Postgresql 9.6 which is supported as per the docs:
https://confluence.atlassian.com/adminjiraserver078/supported-platforms-947188411.html
However, I keep getting the following errors:
GUI
When attempting to create the admin user:
"Cannot add user, all the user directories are read-only"
App Logs
2018-05-15 02:15:27,203 http-nio-8080-exec-11 ERROR anonymous 135x39x1 - 0:0:0:0:0:0:0:1 /secure/SetupDatabase!default.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Error importing data: java.lang.RuntimeException: Could not get unique fields for table 'AO_21D670_WHITELIST_RULES'
at net.java.ao.schema.helper.DatabaseMetaDataReaderImpl.getUniqueFields(DatabaseMetaDataReaderImpl.java:189)
at net.java.ao.schema.helper.DatabaseMetaDataReaderImpl.getFields(DatabaseMetaDataReaderImpl.java:83)
at net.java.ao.schema.ddl.SchemaReader.readFields(SchemaReader.java:126)
at net.java.ao.schema.ddl.SchemaReader.readTable(SchemaReader.java:110)
at net.java.ao.schema.ddl.SchemaReader.access$000(SchemaReader.java:62)
at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:99)
at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:97)
at com.google.common.collect.Iterators$8.transform(Iterators.java:799)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
at com.google.common.collect.Iterators.addAll(Iterators.java:362)
at com.google.common.collect.Lists.newArrayList(Lists.java:160)
at com.google.common.collect.Lists.new`ArrayList(Lists.java:144)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:97)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:88)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:81)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.doCleanup(ActiveObjectsDatabaseCleaner.java:58)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.cleanup(ActiveObjectsDatabaseCleaner.java:45)
at com.atlassian.activeobjects.backup.ActiveObjectsBackup.clear(ActiveObjectsBackup.java:160)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.removeActiveObjects(DefaultDataImportService.java:992)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:727)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:324)
at com.atlassian.jira.startup.DatabaseInitialImporter.importInitialData(DatabaseInitialImporter.java:56)
at com.atlassian.jira.startup.DatabaseInitialImporter.importInitialData(DatabaseInitialImporter.java:48)
at com.atlassian.jira.web.action.setup.SetupDatabase.doDefault(SetupDatabase.java:141)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
... 2 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
... 48 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:62)
... 12 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 58 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 23 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.postgresql.util.PSQLException: ERROR: column i.indproc does not exist
Hint: Perhaps you meant to reference the column "i.indpred".
Position: 610
DB Logs:
2018-05-15 15:31:37 AEST [16251]: [405-1] user=jirauser,db=jira,client=10.3.2.13 10.3.2.13(34186) (0:42703)ERROR: column i.indproc does not exist at character 610
2018-05-15 15:31:37 AEST [16251]: [406-1] user=jirauser,db=jira,client=10.3.2.13 10.3.2.13(34186) (0:42703)HINT: Perhaps you meant to reference the column "i.indpred".
2018-05-15 15:31:37 AEST [16251]: [407-1] user=jirauser,db=jira,client=10.3.2.13 10.3.2.13(34186) (0:42703)STATEMENT: SELECT NULL AS TABLE_CAT, NULL AS TABLE_SCHEM, ct.relname AS TABLE_NAME, NOT i.indisunique AS NON_UNIQUE, NULL AS INDEX_QUALIFIER, ci.relname AS INDEX_NAME, CASE i.indisclustered WHEN true THEN 1 ELSE CASE am.amname WHEN 'hash' THEN 2 ELSE 3 END END AS TYPE, a.attnum AS ORDINAL_POSITION, CASE i.indproc WHEN 0 THEN a.attname ELSE ip.proname || '(' || ai.attname || ')' END AS COLUMN_NAME, NULL AS ASC_OR_DESC, ci.reltuples AS CARDINALITY, ci.relpages AS PAGES, NULL AS FILTER_CONDITION FROM pg_class ct, pg_class ci, pg_attribute a, pg_am am, pg_attribute ai, pg_index i LEFT JOIN pg_proc ip ON (i.indproc = ip.oid) WHERE ct.oid=i.indrelid AND ci.oid=i.indexrelid AND a.attrelid=ci.oid AND ci.relam=am.oid AND ai.attnum = i.indkey[0] AND ai.attrelid = ct.oid AND ct.relname = 'AO_21D670_WHITELIST_RULES' ORDER BY NON_UNIQUE, TYPE, INDEX_NAME, ORDINAL_POSITION
The does your db user/schema have all permissions on the database ?
Yup - it's a known issue.
