I'm testing JIRA 7 EAP and I have some questions:
You can follow the rapid upgrade method: https://confluence.atlassian.com/jira/upgrading-jira-using-a-rapid-upgrade-method-312738529.html
Not sure what do you mean by the second part of the question.
Just be aware of the changes in JIRA 7: https://developer.atlassian.com/jiradev/latest-updates/preparing-for-jira-7-0
Jobin Kuruvilla but I can have installed JIRA Service Desk without JIRA Core application. Workflows would be stored in JIRA Service Desk then?
No. If you take SD, you get Core as part of it.
Yes, they rely on it for all the stuff you're asking about.
Then, if you only have SD, you only pay SD license although SD have a JIRA Core inside. Isn't it?
Yes, you'll only pay the SD licence. But it is twice what Core is. Because half of it is for Core probably.
This should help: https://developer.atlassian.com/display/JIRADEV/Preparing+for+JIRA+7.0
Jobin Kuruvilla thank you. What I mean is in JIRA 6 a workflow is related to the JIRA application. A board is related to JIRA Agile application. So, in JIRA 7, if you have some applications instaled, JIRA Core will allways store the workflows?
Yes, correct!
Thank you for your quick answer @Nic Brough [Adaptavist].
I'm just testing it and I have not planned to use it in a Production environment because it's still an EAP version.
However I was looking for documentation and I didn't found any about it.
So, the standard upgrade process will be still valid? Executing the bin or exe file of the JIRA 7 version would upgrade the JIRA 6 version?
About the applications, if you have some applications, JIRA Core always store the items such as workflows?
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
