Hi All,
How to configure JIRA for AD so that only users satisfying:
CN=GGS_APPS_JIRA_GOP,OU=APPLICATIONS,OU=GOP,DC=gop,DC=link
can log in,
Thanks a lot!
You can found the solution here:
Great! That works... And how to do that users from this filter are part of jira_users (I mean: which can log in)? Cheers, F.
For that you need select the option "Read Only, with Local Groups" in LDAP Permissions section and then appears the field "Default Group Memberships" where you can put the default group. More info: https://confluence.atlassian.com/display/JIRA/Connecting+to+an+LDAP+Directory
Hey Frédéric,
I recommend you to take a look on the following articles from our documentation, which may be very useful:
-- Arthur Gonçalves
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
