JIRA Audit via API
Adam_G March 9, 2018
Using the documentation from here, I'm not exactly sure how to put in to, from, and filter information. The to/from parameters seem to be string data types, but I have no documentation on how to format the strings to get data back. Any help would be greatly appreciated.
I'm trying the below, but it seems to hang up on the date format being wrong.
/rest/api/2/auditing/record?filter=Permission&from=03-01-2018&to=03-08-2018
Kyle Moseley
March 9, 2018
Try this format:
2014-03-19
If that doesn't work, try including time, like in this format:
2014-03-19T18:45:42.967+0000
the ISO-8601 format is what did it. Thanks Kyle!
Katie Black
June 4, 2018
Exactly which format did you use? I have tried a few of them from here: http://support.sas.com/documentation/cdl/en/lrdict/64316/HTML/default/viewer.htm#a003169814.htm and still no luck.
Mario Ofner July 10, 2018 edited
Hy Katie
This Timestamp Format that worked for me is
2018-01-01T00:00:00.000Z
Thank's Adam for pointing into the right direction
Puja Nayak (IN) September 12, 2018
The audit log api is not pulling add-on installation log details.Any idea how to get that using rest api?
