×Hi, I am trying to setup an automation to transition subtasks to status [CLOSED] if the main task has routed to [CLOSED] status. To clarify further, the subtasks are currently in the initial status of the workflow. May I know how do I achieve that? Because when I tried to setup in automation, below error message was shown:
Does the CLOSED status has the global transition enabled? If not, and you don't want to enable it, you have to make sure that a transition to CLOSED exists from any status the subtasks may be.
Hi @Jeff Boon
Welcome to the community!
I couldn't get the last part of your rule. However, your rule should look like this
The same error were shown:
