JIRA Automation. How to Change accountID rules to UPN?
Tony Montana
April 19, 2024
Hello. We changed our logins from sAMAccountName (login) to UPN (login@domain.com). But I have rules, for example, {issue.Request Participants.accountID} recieved names in login (sAMA type). But, what I need to change for UPN names. cause I have errors.
Jehan Bhathena
Hi @Tony Montana
Not sure I understand the use case here, perhaps you can add an example to explain the use case?
Tony Montana
May 11, 2024
Which examples?
Jehan Bhathena
Can you add more details to what is expected?
Not aware sAMAccountName or upn either, what is the expectation from the automation?
Tony Montana
May 12, 2024
@Jehan BhathenaReal bro.
UPN vs SAMACCOUNTNAME
https://gist.github.com/nordineb/c6b039d7d56ae5d7f3af36bb098b3c3a
What expected. AS I said.
- We changed our logins from sAMAccountName (login) to UPN (login@domain.com).
- But I have rules, for example, {issue.Request Participants.accountID}
This smart thing uses SAM login attribute - format LOGIN
- I need smart expression for UPN - format LOGIN@DOMAIN.NET
Because, rules can't run.
Action details:
Issue condition
The following issues passed:
AC-289
Re-fetch issue data
Issue data re-fetched from server successfully.
Edit issue
Error editing issues
AC-289 (Could not find usernames: tony, john, presley (customfield_10000))
Jehan Bhathena
May 12, 2024 edited
Got it.
About the Edit Issue Error, assuming the custom field is a user drop down, you can try to create smart value with the user name appended with the domain (provided the domain is consistent).
Smart value function "concat(String str)" Should be of use here. Ref https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
Tony Montana
May 12, 2024
This isn't cloud
Jehan Bhathena
