JIRA Automation Plugin
Charles Candale March 13, 2016
Hello Atlassian Answers.
I have installed and enabled the JIRA Automation Plugin.
Can someone please direct me to documentation that shows how to use this?
I cannot see an Automation link under either System or Add-ons.
Thanks.
Charles.
4 votes
Aleks Yenin (Polontech)
March 13, 2016
Please visit this link: <Jira_base_url>/plugins/servlet/automationrules (e.g. http://localhost:8080/plugins/servlet/automationrules). Also You can use administrator search - press 'g' + 'g' while login as admininstrator and input Automation.
Note: if automation link is not avialable - something gone wrong during installation. Check if there is JIRA Automation Plugin in list of all plugins and if it is enabled. If no - refer logs for more information.
sanjay sahuu March 30, 2016
I am also having the same issue, I have the plugin installed and enabled. But sill cannot configure the plugin and rules? Can you please help here.. thanks
I am using JIRA 6.2.5 and JIRA automation plugin 1.5.3
Charles Candale March 14, 2016
Hi Aleks.
I have installed and enabled this.
I am having trouble setting up a rule to auto transition a task when created to Done.
Is there any documentation on how to do this?
Thanks.
Charles.
