JIRA Bamboo Plugin Error
Daniel Farias June 26, 2013
JIRA Bamboo Plugin The plugin allows not enabled, the plugin previously functioned normally and there was no update from him and neither of JIRA.
We try to activate the same plugin in Bamboo and we had the same problem.
The error: The plugin has been installed but cannot be enabled. Please refer to the logs for more information.
Sultan Maiyaki
June 27, 2013
Hi Daniel,
The JIRA Bamboo plugin is actually not a Bamboo plugin but a plugin that should be present in JIRA only. The plugin is shipped in to JIRA by default. You can therefore remove this plugin from Bamboo altogether. In other to that, try the following:
  1. Shutdown Bamboo
  2. Remove the plugin jar from the <tt>$BAMBOO_HOME/plugins</tt> directory
  3. Restart Bamboo
This should fix the issue and Bamboo should be working seamlessly with JIRA.
Sultan
Sultan Maiyaki
June 28, 2013
Hi Daniel,
May I know the version of your JIRA and Bamboo server? Also let us know the version of the JDK in both servers
Daniel Farias June 30, 2013
JIRA version v5.1.7#786-sha1:c37bed1
Bamboo version 3.2.2 build 2602
JDK version 6 update 27
Daniel Farias June 27, 2013
Sultan,
Performed the procedure and even then the tab associated with the Release version does not appear.
I tried again to install the plugin on a new version and still did not work, the error persists both in JIRA as the Bamboo.
Log
<th>Log Message</th><th>By</th><th>Date</th>
Failed to enable plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo) Daniel Farias 27/6/2013 14:32:55
Failed to enable plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo) Daniel Farias 27/6/2013 14:03:24
Installed plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo version 6.1.7) Daniel Farias 27/6/2013 13:32:02
Failed to enable plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo) Daniel Farias 27/6/2013 13:30:30
Installed plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo version 6.1.7) Daniel Farias 27/6/2013 13:29:44
Failed to enable plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo) Daniel Farias 20/6/2013 19:07:20
Installed plugin JIRA Bamboo Plugin (com.atlassian.jira.plugin.ext.bamboo version 6.1.7) Daniel Farias 20/6/2013 19:05:18
Timothy
June 26, 2013
And what does the log say?
