JIRA Burndown chart
Nik Nur Hanisah Hanum Fathi
May 6, 2017
Hello, I am trying to create the JIRA burndown chart. Do you know how i can get the values in the columns below the burndown chart in the JIRA page? I've already found the resolution date from the JIRA database, but finding the date when the task was added into the sprint is the tricky part. Do you know if there is a way to get this ?
Dennis
You mean issues added to an active sprint, so scope changes ?
May 6, 2017
Yes, i am looking for the table where they store the event type and event detail (which includes scope change, burndown, sprint start, etc etc) of when any changes was made in the sprint. The table already exists and can be seen under the burndown chart in jira with the time stamp of when exactly an event occurs. But, I can't seem to find the table in jira database.
Christopher Heritage
Nik Nur Hanisah Hanum Fathi - We are looking for the same thing! Did you have any luck?
Jesse Heidstra
October 12, 2017
Nik Nur Hanisah Hanum Fathi We are looking for the exact same thing. Did you find anything for this problem?
Nic Brough -Adaptavist-
October 12, 2017
As already stated, the system is looking at the issue history to *calculate* most of those things, as they are not stored.
Some sprint data can be found in table AO_60DB71_sprint, but you'll have to read the issue history (changeitem and changegroup) to calculate the rest.
Thank you Nic As Already Stated Brough.
May 6, 2017
It looks at the history for when the sprint field was updated.
