JIRA Calculated number sum
Joe Harmon
I am using the JIRA Calculated field and it isn't giving me the correct results.  I have 5 custom fields.  These fields have values between 0 -3 which can be selected using the single select custom field.  I am then trying to all all of these together to get a number.  My formula is below.
<!-- @@Formula:
issue.get("customfield_11309")+issue.get("customfield_11310")+issue.get("customfield_11311")+issue.get("customfield_11312")+issue.get("customfield_11313")
Let's say for the sake of simplicity that I am selecting the number 1 for each of these.  I would expect it to return the value of 5. However, it is instead putting the numbers side by side and I am getting the value of 11,111
Any help would be great.
Tuncay Senturk
Actually they are same.
Anyway, for sure you have to add null check
&lt;!-- @@Formula:
Object cf1Val = issue.get("customfield_11309");
Object cf2Val = issue.get("customfield_11310");
Object cf3Val = issue.get("customfield_11311");
Object cf4Val = issue.get("customfield_11312");
Object cf5Val = issue.get("customfield_11313");
int sum = ((cf1Val != null ? Integer.parseInt(cf1Val.toString()) : 0 ))
+ ((cf2Val != null ? Integer.parseInt(cf2Val.toString()) : 0 ))
+ ((cf3Val != null ? Integer.parseInt(cf3Val.toString()) : 0 ))
+ ((cf4Val != null ? Integer.parseInt(cf4Val.toString()) : 0 ))
+ ((cf5Val != null ? Integer.parseInt(cf5Val.toString()) : 0 ));
Tuncay Senturk
So, any update? Does this code work?
Joe Harmon
No for some reason it doesn't work.  I copied it in just as you have it.  Is there a way to debug it?  Does it output to any specific logs?
Tuncay Senturk
It should definitely work.
Did you return the value.
It should be as below
<!-- @@Formula:
Object cf1Val = issue.get("customfield_11309"); Object cf2Val = issue.get("customfield_11310"); Object cf3Val = issue.get("customfield_11311");
return sum;
Like • Jen Adel likes this
Joe Harmon
It's working.  Thanks for all your help.
Tuncay Senturk
Glad to hear that. So please accept the answer for the further usages.
Joe Harmon
done
Tuncay Senturk
You're getting 11111 because you're concating five 1
You should cast the result to integer before adding.
Integer.parseInt(...) + Integer.parseInt(...) + ...
 or
(Integer)issue.getCustomFieldValue(cf1) + (Integer)issue.getCustomFieldValue(cf2) + ...
Joe Harmon
Thanks for the response.  For some reason, (Interger)issue.getCustomFieldValue("customfield_11313") isn't returning a value for any of the plugged in custom fields.
Tuncay Senturk
May 23, 2018 edited
What is your custom fields' (11309, and others) type?
And what does below statement return?
Tuncay Senturk
By the way, cf1 is not "customfield_11309"
CustomField cf1 = customFieldManager.getCustomFieldObject("customfield_11309")
Joe Harmon
May 23, 2018 edited
All 5 custom fields are "Select List (single choice)" custom files.  I then have in the list the values of 0, 1, 2, 3.  But I suspect that it is being seen as text and not a numeric value.
issue.get("customfield_11309") returns the current set value of that field (currently set to 2)
Tuncay Senturk
OK, then try this one
int cf1Val = Integer.parseInt(issue.get("customfield_11309"))
int cf2Val = Integer.parseInt(issue.get("customfield_11310"))
int cf3Val = Integer.parseInt(issue.get("customfield_11311"))
int cf4Val = Integer.parseInt(issue.get("customfield_11312"))
int cf5Val = Integer.parseInt(issue.get("customfield_11313"))
int total = cf1Val + cf2val + cf3Val + cf4Val + cf5Val
Joe Harmon
Nope, that one didn't work, but this one does if all the fields are set:
<!-- @@Formula:
Integer.parseInt(issue.get("customfield_11309"))+
Integer.parseInt(issue.get("customfield_11310"))+
Integer.parseInt(issue.get("customfield_11311"))+
Integer.parseInt(issue.get("customfield_11312"))+
If any of the fields are set to none or not set, then it doesn't work.
Register now
