I want to change font face and size in JIRA , specially for the fonts inside the any text box. The reason is while the -noformat- is using courier and can be fully aligned, i want the same in a textbox, so the user dont need to make unnecessary adjustments during text editing.
Hey,
I have found few link which might be helpful regarding your requirement here:
I hope that helps.
