JIRA Cloud Add-on: Top Menu Drop Down Example
All-In-One Support
April 4, 2017
Hello!
Can someone please share an example of atlassian-connect.json which creates a drop down menu in the top level menu?
My drop down menu works fine as long as all the top bar menu items fit on the bar. At low resolutions or when there are more items on the bar, JIRA creates a "More" menu item and then the sub items from the drop down menu stop showing up.
Here is the "Modules setion from my json"
"modules":{
"webItems":[
"name":{
"value":"Main"
"location":"system.top.navigation.bar",
"url":"/abc",
"key":"jira-dropdown"
"generalPages":[
"name":{
"value":"Action A"
"url":"/actiona",
"key":"jira-actiona",
"location":"jira-dropdown/jira-section",
"weight":1
"name":{
"value":"Action B"
"url":"/actionb",
"key":"jira-help",
"weight":2
"webSections":[
"name":{
"value":"Main Section"
"location":"jira-dropdown",
"key":"jira-section"
Sam Hall
April 4, 2017
Hi - since this is development related, you might want to try asking this over at: https://community.developer.atlassian.com as well if you haven't already.
Hoepfully someone over there will be able to help.
