Sign up Log in
JIRA Create on Transition Plugin Availability
Craig Hylwa
Is this plugin still available?
Does funtionality provide for creating multiple sub-tasks via the post function?
Nic Brough -Adaptavist-
January 4, 2012
I did it by adding several post-functions, one for each task.
Craig Hylwa
Hi Nic
Can you explain how to access the function of this plugin I have installed it succesfully but can not figue out how to access it. I am somewhat new to Jira
thx
January 4, 2012
Go to edit the workflow, and look for post-functions, it should be available as one of the post-function types you can run.
Craig Hylwa
OK found it! Great help save me alot of time.
Does it matter where I place it in the sequence of post functions? Meaning can it be placed after the last post function " Fire Issue Created event that can be processed by the listeners" ? or should it be before that?
Craig Hylwa
OK done!
thx for the help
January 4, 2012
I'd place it just before "index this issue", but I don't think it really matters too much.
Bob Swift
January 5, 2012
Here is the documentation reference for others: JIRA Create on Transition Plugin or on the plugin exchange at https://plugins.atlassian.com/plugin/details/697735?versionId=724661
