1) I have created a Story
2) Two Sub Task ( Subtask1 and Subtaks2)
I would like to show in JIRA dashboard hierarchy where Issue is parent and Subtask is Child along with Progess.
How can i do that.
Hi Amit,
I would recommend you to try the "Filter Results" gadget. This gadget returns values based on the JQL filter you use.
This way, you would need to create an filter that return the issues and it's sub-tasks an display them in the filter.
Give a try, trying to build the filter and using the gadget.
I'm also sending you documentation, regarding to using gadgets and creating filter on JQL.
https://confluence.atlassian.com/adminjiracloud/using-dashboard-gadgets-776636252.html
https://confluence.atlassian.com/jiracore/blog/2015/07/search-jira-like-a-boss-with-jql
That does not show the status of the sub tasks though
Although this answer is accepted, I do not think it properly answers the original question. I'm in the same position and want to display the hierarchy of my stories and their child sub-tasks. The "Filter Results" gadget is not sophisticated enough to achieve this goal.
I easily created a filter that lists my stories and all of their sub-tasks, I passed in my filter to the "Filter Results" gadget but the gadget does NOT offer a way to organize my output by issue hierarchy, which is what is desired. Everything appears jumbled together. The best I could do with the gadget, is display the columns containing the "key" and "Linked Issues" for each result returned from my filter and by looking at the information I could match the keys up manually...which is just unacceptable.
I want a gadget that will clearly display my stories with their current status and underneath each story, preferably with some type of indentation, I can see all of the sub-tasks for my stories with their current status:
My_Story1 Current_status
Sub-task1 Current_status
Sub-task2 Current_status
My_Story2 Current_status
Sub-task3 Current_status
Sub-task4 Current_Status
etc
Currently, I haven't found any gadgets in Jira that offer this....
Hi @FM
Welcome to the community !!
If you would be interested in a mktplace app for a ready made solution, you can try out
And generate insights such as:
- % complete based on time spent and story points at each hierarchy level
- Sum up Time Spent, Org Estimate, Time Rmng, custom number
fields
- View the full Jira Issue Type hierarchy of Linked issues,
Portfolio/Advanced Roadmaps, Epics, and Subtasks up to 10 levels.
- Export your reports to a CSV file
Thank you! This is more along the lines of something I'm was looking for :)
Found another post that helped me and this is part of how I can filter it out.
I'm searching in a project, that has a epic, and there are stories under that epic with a subtask.
This is how I can find them all
project = "PROJNAME" AND issuetype in (Sub-task) AND status = In_Progress AND parentEpic = "EPIC NAME"
Help us plant more trees
